Dangi Posted June 5, 2018 Report Posted June 5, 2018 Hello, I've got an urgent question. We would like to run cues with crossfade, not with the "Go" button. I suppose that "Manual Fader 2 way" mode is the way to go here. If I switch to this mode, I can't manually start cues with for example "Go + 5" anymore (which works in HTP master mode), which is not convenient for rehearsals. Is there a workaround or better way which I haven't found yet? Thanks in advance! Quote
Jon Hole Posted June 5, 2018 Report Posted June 5, 2018 On 6/5/2018 at 3:37 PM, Dangi said: We would like to run cues with crossfade, not with the "Go" button. I suppose that "Manual Fader 2 way" mode is the way Expand On 6/5/2018 at 3:37 PM, Dangi said: If I switch to this mode, I can't manually start cues with for example "Go + 5" anymore Expand Correct - if you choose to use the fader to manually crossfade, rather than the GO button and the programmed times, the GO button stops working. On 6/5/2018 at 3:37 PM, Dangi said: Is there a workaround or better way which I haven't found yet? Expand You can select the "Next" cue (Yellow line) using a mouse or touchscreen, and then the fader will fade to that cue Quote Jon Hole linkedin.com/in/jonhole
kgallen Posted June 5, 2018 Report Posted June 5, 2018 On 6/5/2018 at 3:37 PM, Dangi said: I suppose that "Manual Fader 2 way" mode is the way to Expand I don't see that ZOS-8363 is fixed in 7.9.4 (Release Notes) so I'm not sure if 2-way fader is going to work? Quote
Howartp Posted June 5, 2018 Report Posted June 5, 2018 On 6/5/2018 at 5:18 PM, kgallen said: I don't see that ZOS-8363 is fixed in 7.9.4 (Release Notes) so I'm not sure if 2-way fader is going to work? Expand kgallen, we can't see whatever you posted under your sentence there? Quote
Dangi Posted June 5, 2018 Author Report Posted June 5, 2018 Well, thanks for answers! Problem solved for now, since the guest technician is ok to work with the Go-Button. A Workaround that came to my mind is to save each cue on a playback fader and program each playback button to trigger a "go", so we could have both worlds in the future. @ zero88: Maybe it could be possible to let us use the Go-Button when in Manual-Fader-Mode? I don't see any reason why it is switched off. Quote
kgallen Posted June 5, 2018 Report Posted June 5, 2018 On 6/5/2018 at 5:45 PM, Howartp said: kgallen, we can't see whatever you posted under your sentence there? Expand It's a link to the beta test forum for those that can see it. Peter, I thought you were a beta tester too? Kevin Quote
Howartp Posted June 14, 2018 Report Posted June 14, 2018 On 6/5/2018 at 7:26 PM, kgallen said: It's a link to the beta test forum for those that can see it. Peter, I thought you were a beta tester too? Kevin Expand Apparently not! I am for various forums/products, but not for Zero88. Quote
