van den abbeele Eric Posted June 3, 2018 Author Report Posted June 3, 2018 I have two desk one rescue 48 chanels « jester » from zéro 88 ans thé FLX with wings. Si with thé Flx and Numbers or projecteur that I can have I Think (if there is no lire problem with bug) i will buy (when I will have money) a second Wing in this way I will have direct Control and 48 chanels and playback on 24 chanels for animation and chaser. but first I Walt to underdstand the two yesterdzy problems so nice day Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
kgallen Posted June 3, 2018 Report Posted June 3, 2018 Well done Eric! Can you upload your show file here so Edward can take a look at what might have caused your spurious light? There can be many reasons! Earlier we were talking about tagging for your effect. I found this Knowledgebase article: http://support.zero88.com/Consoles/ORB-XF/1014189311/What-is-Tagging.htm Quote
van den abbeele Eric Posted June 3, 2018 Author Report Posted June 3, 2018 I go on "what is tagging", but not understand all ... Just to know différence between the different option about tag and what it will do with light.... SO I Keep my show and I can send it here... For be analyzed By Edward or Jon... In you theater what option you use ? Smart Tag ? (I must understand what is the use of Smart Tag...) thank for your help Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
van den abbeele Eric Posted June 3, 2018 Author Report Posted June 3, 2018 spectacle domino.isf Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
van den abbeele Eric Posted June 3, 2018 Author Report Posted June 3, 2018 after continuing menu visit with my yesterday performance file, I see In source / intensity window sometimes there is "D" default value and "O" and sometime no value (without different manipulation from me during recording...) Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
van den abbeele Eric Posted June 3, 2018 Author Report Posted June 3, 2018 So I find a solution for UV and AMBER. (Wheel encoder must be turn about 40 times before to have max level. And same for return to zero. So I create a Palette with UV on and UV Off and same with Amber. Like I explain three or four days before, I using a Lot Amber and UV... Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
kgallen Posted June 10, 2018 Report Posted June 10, 2018 On 6/1/2018 at 10:26 AM, kgallen said: Ooooo, interesting... thanks Edward! Good article by the way, I'll give that a go... 😊 Edward - the Windows 10 PC IP setting instructions aren't correct (certainly not as April 2018). Can you elaborate/update in the article? Thanks. Quote
Edward Z88 Posted June 11, 2018 Report Posted June 11, 2018 Hi Kevin, What part of the instructions aren't correct? This is working for me across a few different Windows 10 PCs. I have made a slight tweak to the article, but still following the same process. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted June 11, 2018 Report Posted June 11, 2018 Hi Edward, So these are the instructions in the KB: To set the IP address of a PC as per Windows 10: Right click Start, and choose "Network Connections", to open Control Panel Double Click on "Ethernet" Double click “Internet Protocol Version 4 (TCP/IPv4)”, and click “Use the Following IP Address” then set the IP to 2.1.1.10 and the subnet to 255.0.0.0, and click OK. The sequence is a little longer than the list above - I've finally found it. I guess if you do this every day, then you know where it is! Start, "network connections" just gets me some useless web searches. Start "Control Panel" gets me of course to control panel app, but it's not at all clear how to then get to somewhere to set a fixed IP address (rather than say DHCP). I know the form you refer to but can't for the life of me find where the darn thing is in Win 10. Of course, they try to hide this kind of low level stuff more and more - it's comparable to Jon not wanting us to be able to access DMX values on the console! 😋 So finally I've found it: So once at Control Panel, we take "Network and Internet" then "View Network status and tasks"? Then "Connections: Local Area Connection" Then "Properties". Then select "Internet Protocol Version 4", Then "Properties". Then At last "Use the following IP address". 😆 One other question - I tried to use Phanton ZerOS with Capture - is that possible, or does it only work with a real desk? Thanks, Kevin Quote
Edward Z88 Posted June 11, 2018 Report Posted June 11, 2018 Hi Kevin, The 3 steps are still working for me. When you right click on Start, what options do you get? Do you not see a "Network Connections" option? The link below shows you how to connect Phantom ZerOS will the Capture file. This can be done on a single PC without the need of an Unlock Dongle. http://support.zero88.com/988883201/Connecting-Phantom-ZerOS-to-Capture-Argo.htm Hope that helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted June 11, 2018 Report Posted June 11, 2018 Edward. That will be the critical ‘right click’ bit... 🤦♂️Doh. Quote
