Franz Posted May 28, 2018 Report Share Posted May 28, 2018 Hi, i´ve been looking for some clear options... Is there a way to clear the programmer "on time"? On other desks i´ve used there is an option to enter a number, say i press 5 then clear and the programmer releases on 5 sec. Or release on go is also very useful when you make changes to a fixture live and automatically release this when you press go on a cuelist. Is there anything like this in Solution? Thanks! Quote Link to comment Share on other sites More sharing options...
keredyelesob Posted May 28, 2018 Report Share Posted May 28, 2018 From what I can remember, on the solution there should be a programmer time within the special keys. This should do what you want. Quote Link to comment Share on other sites More sharing options...
Franz Posted May 28, 2018 Author Report Share Posted May 28, 2018 Thanks, tried it but it seems like it clear intensity values on set time but focus and others are not controlled by this. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted May 28, 2018 Report Share Posted May 28, 2018 Hello, Programmer Time will fade syntax, palettes, clearing the programmer, and releasing cue stacks. To setup Programmer time, hold SETUP + tap an empty Playback, and choose Programmer Time. You can enable Page Lock on this playback so you always have it available if you wish. Click OK, and tapping SUBMASTERS will show you the fade time in the faders window. The Playback’s button will enable or disable the time. See more information here... http://support.zero88.com/1011402011/What-is-Programmer-Time.htm Hope that helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
