Lex Posted May 22, 2018 Report Posted May 22, 2018 I have programed a chase on a MFF and with tap tempo I arranged it to be in sinc with the scene of the artist. I would like to copy this chase to the master playback so it can become part of the cue list of the whole theater show. So I can start the chase with the go button of the master playback and end it when I hit the go button again.. How do I do that? Kind regards lex Quote
Jon Hole Posted May 22, 2018 Report Posted May 22, 2018 Hi Lex, On the Master Playback, record your base cues like normal. Then: On the cue you want the chase to start click "Settings" > "Macros" > "Trigger Cue Stacks" and select the Playback. On the cue you want the chase to finish click "Settings" > "Macros" > "Release Cue Stacks" and select the Playback The chase will fade in with the UP time of the first cue, and the chase will fade out with the DOWN time of the second cue. Quote Jon Hole linkedin.com/in/jonhole
Lex Posted May 22, 2018 Author Report Posted May 22, 2018 Hi Jon, Thanks for your quick reply. I will try this and will reply with the result! kind regards Lex Quote
