I looked the video tips for the FLX lighning desk.
FLX Advent Calendar - Day 24 - Default & Max Level:
https://youtu.be/bnX77Z9ocZw
Is this also possible on the FLX S series? I don't find anything about it in the manual. There is no home button. But perhaps it could be possible to set these values without it.
I use: Zero 88 FLX S48 / ETC ColorSource 40 / GLP Creation 4096 / Chamsys MQ70 / Madrix
Hi Eric,
Home, Default and Topset values can’t currently be set on FLX S. We are looking at implementing this in the future, but in the meantime don’t forget you can save your show file, load it into Phantom ZerOS running as FLX, set your levels and save the show, and then load your show file back in to the FLX S.
Hi Edward,
Thanks for your reply. The posibility to use ZerOS to emulate a normal FLX is a workaround. Normaly i bought my FLX S48 to have a programming solution wich do not need a PC at the event.
Perhaps it would be a possibility to use the update button together with the flash button of a fixture or the Z button together with the update button to get the option to update the home position for the selected and changed fixtures.
Another Solution would be, to allow change of these values again in the setup menue als it worked in older ZeroOS-Version.  On my Solution, which is now in early retirement, I hate the new way of setting these values even with an existing Home-Button.
Uli
you learned how to creep and you learned how to crawl
but you never really learned anything at all
