keredyelesob Posted May 1, 2018 Report Posted May 1, 2018 Hi I have an intermittent problem when connecting the remote app to my FLX desk, this problem has occurred since updating the software to V7.9.4.9. I setup remote options on my desk as follows: Enable Remote Disable security use DHCP I used to use a static IP address with settings of: Enable Remote Disable security IP - 2.141.1.2 Subnet - 255.0.0.0 Gateway - 2.141.1.1 other than my mobile this is the only device on the network. phone IP address is generally 2.141.1.21 (this is DHCP so can change time to time but it normally uses the first in the pool) the error my phone gets is attached. Also tried using another router with ip range 192.168.8.** with subnet of 255.255.255.0 this also had the same outcome. Any ideas? Note: this is since i updated the software. I have since installed it again just in case. Quote
keredyelesob Posted May 28, 2018 Author Report Posted May 28, 2018 Do you know if this is a known issue as I see similar 'remote app' problems popping up on the forum? Quote
Jon Hole Posted May 28, 2018 Report Posted May 28, 2018 On Google Play there’s a Beta app available which is a complete rewrite of the backend - maybe worth giving it a try first before we investigate further? Quote Jon Hole Global Product Manager, Systems and Control
keredyelesob Posted May 28, 2018 Author Report Posted May 28, 2018 Thanks Jon. Will give that a go tomorrow. Quote
martin-144 Posted May 28, 2018 Report Posted May 28, 2018 Hi keredyelesob, I had a similar problem recently. In my case it turned out that the console had the same IP address as the access point connected to it. Which shouldn't happen when using DHCP. But who knows? Just an idea... Martin Quote
keredyelesob Posted May 28, 2018 Author Report Posted May 28, 2018 Hi Martin. Thanks for the pointer but I have checked and checked again. Tested on four routers now all on different ip ranges both with the desk on static ip and dhcp and different cat5 cables. Power cycling everything inbetween changing settings. I will try the beta remote and see if I get any joy. Quote
keredyelesob Posted May 30, 2018 Author Report Posted May 30, 2018 Hi Jon Just tested the new beta android app and it connects no problem, what ever it was stopping me you have fixed in the beta. Plus the whole app looks so much better, I like the full syntax option to record, name, delete, etc, iIcan see it being handy for recording pallets when in the rig. Quote
Edward Z88 Posted May 31, 2018 Report Posted May 31, 2018 Hi Derek, Great, glad you like the improvements! We’ve still got a few tweaks to make, but we’re hoping to release as soon as possible. Edward Quote Edward Smith Product Specialist Email Support
