danh Posted April 19, 2018 Report Posted April 19, 2018 Hi all, Got a few questions about MIDI time code. My school have an upcoming dance show where we want to sync audio tracks coming from a PC with lighting on the FLX. There will be around 15 songs (about 3 mins each) and each song's lighting cues will be stored in a separate playback on the FLX. The best way to do this seems like MIDI timecode. Firstly, can anyone recommend a USB MIDI interface that would be suitable for this? Jon briefly mentions here that (although not ideal) those cheap USB MIDI cables seem to work for MTC, but not MSC (which is ok as that's not what we're using). We are on a tight budget with this so can't get any expensive gear. Secondly, Qlab seems the best bet for controlling the sound and output of MTC, but in the possible situation where we can't get hold of a Mac is there any Windows applications that will handle this? I've seen a program called timelord online, but never used it so am unsure if it would work in this scenario. Would be great if anyone has experience with this and can shed some light on it! Thanks Quote
Edward Z88 Posted April 19, 2018 Report Posted April 19, 2018 Hi Dan, MIDI Timecode from your description will be your best option, as any cue on any Playback can be triggered by MIDI Timecode. MIDI Show Control (MSC) only triggers cues on the Master Playback. For demos, we use the MOTU Fastlane USB MIDI interface... http://motu.com/products/midi/fastlane_usb We use this with QLab for Mac. I haven't used any Windows based software to send MIDI triggers, but I believe software such as Multiplay has this functionality. Hope that helps, any queries let me know. Edward Quote Edward Smith Product Specialist Email Support
lacapella Posted May 11, 2020 Report Posted May 11, 2020 Hello, If you can make a lesson videos about how to make timecode lightshow with MIDI and SMPTE, And maybe Connect with Art-net to PC and connect to 3d light design programmes. It can be perfect :) The videos in Youtube is so basic. Thanks, Quote
Edward Z88 Posted May 11, 2020 Report Posted May 11, 2020 Hello, Welcome to the Zero 88 Forum. 13 hours ago, lacapella said: If you can make a lesson videos about how to make timecode lightshow with MIDI and SMPTE, And maybe Connect with Art-net to PC and connect to 3d light design programmes. It can be perfect For more information on MIDI Timecode on FLX consoles, see below... http://support.zero88.com/990063141 Hope this helps, Edward Quote Edward Smith Product Specialist Email Support
stowedout Posted May 11, 2020 Report Posted May 11, 2020 Don't forget if you need a USB to midi link your school may have external sound cards that include USB & midi in the music room. I use an old Steinberg UR22. It's worth a look if you can borrow one for nothing. Chris Quote
van den abbeele Eric Posted September 20, 2020 Report Posted September 20, 2020 like Zero88 tells in http://support.zero88.com/990063141 link, it's important to have a correct USB/midi device that giving a good protections (opto-isolator) for FLX devices and also the computer and also having good conception. Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
