Mort2376
Betapak 1 Problem
Hi Folks,
Newbie here so please be gentle.
Got an issue with 1 of our betapack 1's. Channel 3 if you turn it on via demux or analogue desk it comes on to about 60% but brings CH4 on with it to 60%.
Same applies if you bring up CH4 first. But if you bring both 3 and 4 up both come on to 100% when full
Is this something simple ?
Thanks in advance.
I'd be looking at the control cable for that rack first (they do fail!) - sounds like a whisker touching two pins.
After that, you'll need to take the mainboard out to check that - if you're happy fault finding a PCB using a multimeter and a soldering iron, then it should take about an hour plus removing/replacing the PCB.
Or...
You could send it me to look at - The Service Guy
