thierry Posted April 18, 2018 Report Share Posted April 18, 2018 Hi everybody, two questions today : - 1 : is it possible to copy several playbacks of one page at same time, and then paste in another page ? - 2 : is it possible to record scenes from playbacks ? Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted April 18, 2018 Report Share Posted April 18, 2018 8 minutes ago, thierry said: - 1 : is it possible to copy several playbacks of one page at same time, and then paste in another page ? No, it's not. However - are you aware of "Page Lock" - it might be what you need? 8 minutes ago, thierry said: - 2 : is it possible to record scenes from playbacks ? Yes, you need to be either in: Non Tracking mode Tracking mode with "Smart Tag" enabled Tracking mode with "Cue Only" enabled In any of these situations, when you record a cue, it will include everything being played back from the active Playbacks. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
thierry Posted April 18, 2018 Author Report Share Posted April 18, 2018 2 hours ago, Jon Hole said: No, it's not. However - are you aware of "Page Lock" - it might be what you need? No, it's just a question of copying everything in one time without returning back each time to the playback i'm copying from. But you're right, if i put correctly at the right place the "Key" cues that i often use (ex 1 to 5, page 1), "Page Lock" can help keeping it in other pages (1 to 5, every pages used) 2 hours ago, Jon Hole said: Yes, you need to be either in: Non Tracking mode Tracking mode with "Smart Tag" enabled Tracking mode with "Cue Only" enabled In any of these situations, when you record a cue, it will include everything being played back from the active Playbacks. Thank you, i'll make a try and let you know Regards, Thierry Quote Link to comment Share on other sites More sharing options...
thierry Posted May 4, 2018 Author Report Share Posted May 4, 2018 Everything fine with my "record" tries, thank you Quote Link to comment Share on other sites More sharing options...
