Andrew-cz Posted April 12, 2018 Report Share Posted April 12, 2018 Hi, after a two channels of the dimmerstoped working. I unsoldered the transformer and found out that the primary part of it, is burned. After looking for spare I found that is probably custom made. So I looked in this forum and found that is quite common problem. My question is if you sell the transformers as spare part, or do you knou about some common alternative. Or what's the price of the whole PCB. The serial of the dimmer is: 0030721 08440022 The code from the transformer is 556100 07/15/08. Thanks in advance for any advice and sorry for my not good english. Kindly regards Ondrej Blazik Quote Link to comment Share on other sites More sharing options...
KWR88 Posted April 12, 2018 Report Share Posted April 12, 2018 Hi Ondrej, I believe you have also emailed my colleague Franck Tiesing as well on this. He has forwarded your mail to me. I will make a reply direct to you on this. Quote Link to comment Share on other sites More sharing options...
