scoloco2 Posted April 10, 2018 Report Share Posted April 10, 2018 I've been trying to save an effect but I can't figure out what can be causing the issue. Here is what I have been doing: 1) Select 4 Chauvet Intimidator Beam LED 350 fixtures and apply a vertical line effect 2) With the same 4 fixtures selected, apply a chaser effect and then offset it. This was to give a strobe + moving effect. 3) Everything works well until I have to save and going back to the saved cue the chaser effect is gone leaving only the vertical line effect This is using the standard FLX running ZerOs 7.9.3. What can be done so I can save this effect? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted April 10, 2018 Report Share Posted April 10, 2018 Hello, The instructions you've listed should give the effect you're after. Feel free to attach or send me your show file, and I'll take a look to see what the issue is. As a separate note, ZerOS 7.9.3 has now been superseded by ZerOS 7.9.4 available to download here... http://zero88.com/forum/files/file/17-zeros-794/ Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
scoloco2 Posted April 10, 2018 Author Report Share Posted April 10, 2018 Hi Edward, I won't be able to get the showfile until Sunday. I will also update the to the newest ZerOS version - maybe that might solve our problem! Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted April 10, 2018 Report Share Posted April 10, 2018 Hi, No worries. There doesn't seem anything obvious from your description, so let me know how you get on after updating. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
