I've been trying to save an effect but I can't figure out what can be causing the issue. Here is what I have been doing:
1) Select 4 Chauvet Intimidator Beam LED 350 fixtures and apply a vertical line effect
2) With the same 4 fixtures selected, apply a chaser effect and then offset it. This was to give a strobe + moving effect.
3) Everything works well until I have to save and going back to the saved cue the chaser effect is gone leaving only the vertical line effect
This is using the standard FLX running ZerOs 7.9.3.
What can be done so I can save this effect?
The instructions you've listed should give the effect you're after. Feel free to attach or send me your show file, and I'll take a look to see what the issue is.
As a separate note, ZerOS 7.9.3 has now been superseded by ZerOS 7.9.4 available to download here...
http://zero88.com/forum/files/file/17-zeros-794/
