Edward Z88 Posted June 8, 2018 Report Share Posted June 8, 2018 Hi Eric, If you don't see fade times available for a cue, it means there is no values changing from the previous cue. For example if in cue 1 you have recorded your fixtures at 100%, and you then tap record to save cue 2, you won't see any fade times, as cue 1 is identical to cue 2. Regarding fixtures selecting, do you still see the issue happening if you tap SETUP -> System Settings -> Auto Select Channel on Fader movement -> Disabled? Let me know how you get on. If it happens again, please take a picture of the Output Window and the console's faders. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted June 8, 2018 Author Report Share Posted June 8, 2018 So for the fade I find the solution there was in fact no intensity change ... so Before to read your answers I change a intensity value and fade Time Come without problems for the MMF fade Do I must dosables this.flnction ? Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
kgallen Posted June 8, 2018 Report Share Posted June 8, 2018 3 hours ago, van den abbeele Eric said: for the MMF fade Do I must dosables this.flnction ? Eric - Edward just wants you to disable this function to try to debug your spurious light problem. Normally it is convenient to leave this setting enabled so when you move a channel MFF the channel is selected. Quote Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted June 8, 2018 Author Report Share Posted June 8, 2018 Thank you Kevin ... Indeed I assumed that if I removed the detection of MMF fader I have to manually activate the playback button, which is not a problem on some CUES, but on a show like I'm doing over 260 CUES, and the order of 48 machines, there I think there is a waste of time ... But hey, I think indeed that this bug is not quite normal ... Because it is not logical that the control room, can control itself a lighting of MMF button and with that a projector (or group of projectors ...) thank for your help ! Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted June 8, 2018 Author Report Share Posted June 8, 2018 ello again, Question about the aspect of the instructions for use ... In fact I can see that a number of sections are no longer news ... Will there be a new PDF version more current? For example, I wanted to see for the chaser, how to work on speed ... Chase Speed Option, which I can not find in the Setup menu .... And looking a little in different menus, I can not find. I had actually a normal playback that I wanted to convert to chase and I found myself with all the sequences too fast ... and the Fades times of my playback before convertions were lost ... here thank you for your help that is positive and I'm happy to have this console outside my ghosts .... Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
kgallen Posted June 8, 2018 Report Share Posted June 8, 2018 2 hours ago, van den abbeele Eric said: For example, I wanted to see for the chaser, how to work on speed ... Chase Speed Option, which I can not find in the Setup menu .... And looking a little in different menus, I can not find. I had actually a normal playback that I wanted to convert to chase and I found myself with all the sequences too fast ... and the Fades times of my playback before convertions were lost Hi Eric We really should return to the FLX forum for these usage questions. Also it would be good for you to start new topics. This is because we will create a historical reference of knowledge on FLX and other FLX users can both learn and contribute to our collective knowledge. We will not find these answers in this part of the forum after a couple of months. In addition you will find your queries are missed as they are buried with other queries and bug reports -> start separate topics for each query, it's better that way! Regards the chase speed I am no expert but I understand there are two ways: On a playback programmed with a Chase, SETUP+playback button then Chase page will allow you to select Global Tempo or set a private BPM (beats per minute) tempo for this playback - either type BPM number or tap the MFF button for tempo (maybe button has to be configured for this). For global tempo, the speed can be set by a MFF. SETUP+playback button on an unprogrammed MFF will allow you to set that MFF as the tempo adjust on the fader. These should both be in the current user manual. Regards the manual I think this will only get updated with a major software revision. My personal view is that I agree the FLX manual is quite weak for such a complex product when I compare with other Zero88 manual and other brands. Other users have voiced their concerns back on the FLX forum. You can also use the Orb XF manual, the Knowledgebase and this forum for other support, plus whatever you can glean from the Release Notes. My wish would be that a Jon were more inclined towards the FLX product documentation but I suspect this is one aspect of his job he least enjoys, but conversely he does seem to devote his time to product definition, improvements and furthering the range. Edward does seem quite adept with both his product knowledge and descriptions here on this forum so maybe he might be persuaded to work on the product manual. Having the manual in electronic rather than paper form may be one way to keep the official documentation more in step with the software releases. Anyway enough of my waffle, but I hope that answers some of your queries even if it is only from another users perspective. Kevin Quote Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted June 11, 2018 Author Report Share Posted June 11, 2018 ole still a problem during my encoding this Sunday. I was working on two faders and suddenly without touching anything a led that turns on another fader and 30 seconds later a second LED that turns on ... And we see on the screen that the selection is active ... My ghosts are still here ... Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted June 11, 2018 Author Report Share Posted June 11, 2018 Last photo can not upload... But we can see on the photo, Two chanels selected... Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted June 11, 2018 Author Report Share Posted June 11, 2018 Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 11, 2018 Report Share Posted June 11, 2018 Hi Eric, I understand your problem now. This is due to the sensitivity of “Auto Select Channel on Fader Movement”. This is to be revised in the next software update, to stop this happening. In the meantime if this is causing you problems, you can turn it off by tapping SETUP -> System Settings, and Disable the option. Any queries let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted June 13, 2018 Author Report Share Posted June 13, 2018 Hello, Thanks for your help. I will do it. Then the only trouble to do this is that to gain access to a projector, it will be necessary to alleviate the button (activation of the LED) then open the fader. This is two actions instead of one ... A bit of time wasting on a long encoding ... So if I understand correctly it is a great sensitivity of the Faders that makes that from time to time put the LED function of the MMF fader ? By cons what I do not understand is that during my first show, I had indeed the LED of a MMF button that was lit, but without I move the Fader, the intensity was mounted all alone at 30/35% (Fader was on Zero). And so I had to mount the Fader to reach the value of the intensity and to lower it to zero to turn off the projector on stage ... In fact it looks as if there was an invisilble order to turn on the LED + the projector on stage during the performance ... Thanks a lot for your help! Eric VDA Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 14, 2018 Report Share Posted June 14, 2018 Hi Eric, That is correct, we are going to adjust the auto select sensitivity. The buttons are used to select the fixture, so that you can control it further. Therefore if you wish to turn this setting off, all you’ll have to do is manually select the fixture you wish to control further- you don’t need to press the button before moving the fader. If fixtures seemed to be randomly turning on, can you remember what colour the fixtures intensity was displayed as in the Output Window? This will help to determine why that might be happening- such as an auto cue for example. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted June 14, 2018 Author Report Share Posted June 14, 2018 Good evening, I recorded this solution (Auto Select Channel on Fader Movement mode off) In fact I may be able to keep this option when recording and turned off during shows ... Then I remember the color screen ... But it seems to me that the color was white ... But to be sure, I must check next time it will happen and if I can take a picture ... (if it is short of repetition because in spectacle the priority is to be able to put out the lights which could turn on by mistake) Then I expect to buy Capture to continue working with the control room without having installation ... (I asked for a Quote, certainly it is not given for my association, in view of the expenses already made with the FLX + Wings + touch screen, but on the other hand it can allow me to explore further the other functions of your desk. I hope as soon as possible to make videos in French to help and envy future users. Thanks for the help bring! Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted June 21, 2018 Author Report Share Posted June 21, 2018 Hello I Need Help I m stil trying to connect FLX to Capture... Write on this Topic Thank for your help... Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted June 23, 2018 Author Report Share Posted June 23, 2018 Ok i underdtand But I see tha schift + record it s a Quick step of différente option un record Windows so if i Wanr’t to use during a dance moving light on a other playback I can at this Time change option... i must experiment différents things ... so I did more attention about playback bouton and some Times there is one that swchitch on with out action from me I can really think that there a mystérious gosth on my desk. so now I go to bed bécause today i was recording about 245 cues Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted June 23, 2018 Author Report Share Posted June 23, 2018 In 20 days I did 5 performance and Time after Time things go better ! so Next week I ve two more performance and week after one performance ... And everytime I can see that this FLX look to be thé right light commander ! thank for this Good production ! Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted July 7, 2018 Author Report Share Posted July 7, 2018 Hello This Tuesday was another show. And outside the worries of MMF buttons that are triggered from time to time all alone, (because I prefer for now keep the ON option on the movement of the fader and the setting of the button) for the rest everything works well and gives satisfaction. The small gaps are at the level: - Effects, more option in order to be able to prescribe additional movement options for the aotomatic as well as color variations (Automatic and LED) and also chases. (Traditional and LED) In fact, when you have the time to program, it's not a problem. (That's what I'll certainly be able to do with Capture) but in the case where the time is lacking it is there to have a few things programmed in addition would be good. Second lack - it is for projecteus working in Red Green Blue White Amber. The fact that all 5 colors can not be directly taken into account in color presets makes the FLX try to make amber with RED GREEN BLUE WHITE at best ... MAis misses the amber. And when you go on amber, well then you have to play amber and other colors to find the right tone. So I think an evolution in the future would be positively that the color mixer can take into account what the projector can do. And currently more and more projectors have the included RGBW + A + UV ... The other lack is to have some preprogrammed positions in the automatic. There is HOME. But I think having a position at 25 °, 45 °, 65 ° and 90 ° could be a plus. And then a random position that could serve as a basis for an effect. A bit like when you have ACLs running through the scene. Thus a random creation could save time instead of having to position each projector ... FLX 2 (One day) The other big plus would be to have a second video port to be able to have in front of the eyes directly the window of the cues and on the other screen the access to the windows colors, effect, etc ... Gains of time and faster access to be more productive. And finally when having an evolution of the FLX is to have more encoder wheels, as on the Magic Q. And so to access directly certain settings rather than having to scroll the screen. Then the aspect encoding wheels and more could be included in a Wings option with small LCD screen (as on the consoles sounds from Yamaha, Berhinger, Midas and co) see you soon for other returns ... So I love FLX ! It s really a good desk ! Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 3 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 5 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w Link to comment Share on other sites More sharing options...
Edward Z88 Posted July 9, 2018 Report Share Posted July 9, 2018 Hi Eric, Really glad you're loving FLX! In response to your comments... -We are planning on improving the Effects engine in the next software update, which bring more useful auto effects. Don't forget to quickly get chases you can use an intensity effect, and use one of the quick offset buttons found along the top of the Effects window. -We are indeed seeing more fixtures using Amber, UV, Lime, Indigo etc. Therefore we are still looking into the best and most accurate way to implement this into the ZerOS colour mixing engine. -Regarding the external monitor, in case you didn't know the shortcut to quickly change the external monitor to your Palettes desktop is SHIFT + VIEW. A single tap of VIEW will then take you back to your Programming desktop. Any queries let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
