jimbo-nomads Posted March 7, 2018 Report Posted March 7, 2018 Have an FLX S48 with the recommended Iiyama 17" touch screen monitor. It won't work as touch screen unless it's calibrated. After calibration attached a keyboard so I could press the "Enter" key. It then works fine till it desk & monitor are powered off. When it's all powered on I have to go through calibration every time. Any ideas? Regards, Jim Quote
Edward Z88 Posted March 7, 2018 Report Posted March 7, 2018 Hi Jim, If your FLX S is displaying Press ENTER to complete calibration or Press ENTER to cancel calibration, then you are running out of date software. The latest release software is ZerOS 7.9.3, available to download and install here... Once you’ve got this installed, you should find this solves your issue. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
jimbo-nomads Posted March 7, 2018 Author Report Posted March 7, 2018 Thanks Edward. Planning to upgrade after the current show run finishes. Regards, Jim Quote
jimbo-nomads Posted April 13, 2018 Author Report Posted April 13, 2018 Upgraded & problem solved Quote
Edward Z88 Posted April 13, 2018 Report Posted April 13, 2018 Hi Jim, Great, glad that’s solved your issue. Any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
dramatechws Posted September 19, 2018 Report Posted September 19, 2018 Our touch screen monitor just decided to stop working after moving the desk, can't calibrate it at all, loaded latest OS, still not doing anything - any ideas? The screen is on and displaying everything, but will not calibrate and cannot be used as a touch screen. Quote
kgallen Posted September 19, 2018 Report Posted September 19, 2018 Did you plug the USB cable back in as well as the DVI-D? Quote
dramatechws Posted September 19, 2018 Report Posted September 19, 2018 Hi, yes, both reconnected, might try a different USB cable just in case. Quote
dramatechws Posted September 19, 2018 Report Posted September 19, 2018 Aha, tried a different USB cable, now working, though calibration very sloooow, for some reason, noticed this was the case before. Quote
