ZeuS Posted March 7, 2018 Report Posted March 7, 2018 Hello I bought an flx 24 - 512 yesterday. Its got 7.9.2 software on it. I tried to update to the latest software. Downloaded the usb maker made the bootable stick with 2 different usb stick. It said i just have to plug in to the closest usb to the ethernet and power it up. When i do that nothing happening just boots up normaly. What am i doing wrong? Thank you Daniel Quote
keredyelesob Posted March 7, 2018 Report Posted March 7, 2018 That is the legacy method. All you need to do now is copy the install file to the root of your usb stick.boot up you desk, Plug you stick into the desk and select [setup] [load file] then choose the instal file. From here you can probably follow the instructions on the desk. Hope this helps Quote
Edward Z88 Posted March 7, 2018 Report Posted March 7, 2018 Hi Daniel, Yes Derek is correct, copy the unzipped .exe to the root of a USB stick, plug into the FLX S, and tap SETUP -> Load File, and load in the file. The software update will begin. The process you describe is the old way of performing software updates. Hope that helps, any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
ZeuS Posted March 8, 2018 Author Report Posted March 8, 2018 Thanks a lot i will try it tonight Quote
uli-s_kn Posted May 2, 2018 Report Posted May 2, 2018 Hi, I also tried the old Method today, but haven't had a internet connection at the venue. Now, at home, I read this entry. So for the newest Version I have to load the "ZerOS OS Creator USB - v7.9.4 9-3-2018 BF.exe"-File into the desk. Greetings Uli Quote --you learned how to creep and you learned how to crawlbut you never really learned anything at all
Edward Z88 Posted May 3, 2018 Report Posted May 3, 2018 16 hours ago, uli-s_kn said: Hi, I also tried the old Method today, but haven't had a internet connection at the venue. Now, at home, I read this entry. So for the newest Version I have to load the "ZerOS OS Creator USB - v7.9.4 9-3-2018 BF.exe"-File into the desk. Greetings Uli Hi Uli, Yes, copy the ZerOS OS Creator USB executable file onto the root of a USB stick, and then plug into the console. Tap SETUP -> Load File, choose the software update, and the install will begin. Any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
