StefanB Posted March 3, 2018 Report Share Posted March 3, 2018 Hi everybody, I had a little fashion show on a FLX S48 1024 and tried for one scene to trigger a playback to switch on the lamps one by one and the same back. Triggering the playbacks with the go button worked well, but triggering the playback in the master playback doesn´t work. I attached the part of the showfile. The relevant cues are Cue 82 to trigger the Playback 71, where the lamps switch on one by one and Cue 83 to trigger Playback 72 to switch the lamps off one by one. Standing in Cue 81 press the GO button of Playback 71 ... Lamps go on Then I released Playback71 and started Playback 72 ... Lamps go off. That´s the way I did it during the show. Starting Cue 82 switches on all affected channels at once Cue 83 switches off all affected channels ... Is this a bug? Or am I doing something wrong... One more thing... My first try was a chase with one shot -- This didn´t work at all. The chase stopped at 6 of 9 steps ... very strange!. I´m sorry, I have no showfiles of this try. Thanks Stefan Trigger Test.isf Quote Leap Frog 48, LG L1730SF Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 6, 2018 Report Share Posted March 6, 2018 Hi Stefan, Looking at your show file, Playback 71 has got Trigger on Raise Disabled. This means that remotely triggering this Playback from a cue is also disabled, which is why it isn't triggering from cue 82 of the Master Playback. You can change this setting by holding SETUP + tap Playback 71's button -> Raise & Lower -> Trigger on Raise -> Enabled. Chases set to one shot will run through the cues of the chase once, and then stop on the last step. Hope that helps, any queries let me know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
StefanB Posted March 7, 2018 Author Report Share Posted March 7, 2018 Hi Edward, Thank you, too much parameters for a stupid old man! Never the less, the chase didn't stop at the end. That's why I programmed the cue... I try to get the situation back ... Thx for the quick reply Stefan Quote Leap Frog 48, LG L1730SF Link to comment Share on other sites More sharing options...
keredyelesob Posted March 7, 2018 Report Share Posted March 7, 2018 Are you using the bump button as the tap tempo on the triggered chase? if so I had this problem and it is a known bug in the current software. It has been fixed in the next release due out, (it has been fixed in the beta group) If you have a sub master (chase) triggered by a macro from another cue, then use the bump button as a tap tempo, the triggered cue will not get released using a release macro, if you do not use the bump button as a tap tempo then it should get released with the release macro. Hope this helps Quote Link to comment Share on other sites More sharing options...
