Carwyn Posted March 2, 2018 Report Posted March 2, 2018 Hi Guys and Gals I Need to build a fixture up, it is basically led tape which I've installed on the steps at the venue. controlls need to be RGB and intensity the controller is a 3 channel controller so how would i get the intensity to control the whole unit then HELP Quote
kgallen Posted March 2, 2018 Report Posted March 2, 2018 If I understand you correctly, you have RGB LED tape and the driver (not really "controller") is 3 channel. This is fine, you can have a "virtual intensity" channel - so 4 channels on your lighting desk and 3 DMX channels to the driver. There will be an RGB+virtual intensity already in the fixture library, or just build one in the Fixture Editor. Or attached which is one I built myself for RGB LED tape: led_rgb_vi.ift Quote
Carwyn Posted March 2, 2018 Author Report Posted March 2, 2018 All done now mate werent looking at the fixture editor properly Quote
