Carpo Posted February 20, 2018 Report Posted February 20, 2018 Still waiting for my FLX S24 512 - it is in backorder here in DK :-( Reading alot in the manual and the setup is ready to be loadet when I have the deck/controller in my hands. But how do I make a palette where the moving heads only are working on the "dancefloor" - can´t find it in the manual, do I miss it? What to do so I "restrict" the movements on moving heads for a special area? Quote Carsten Poulsen Carpo Roadshow www.carpo.dk
Edward Z88 Posted February 21, 2018 Report Posted February 21, 2018 Hi Carpo, There is no way of setting a minimum and maximum value for Pan or Tilt, therefore you can't limit the movement. You can however program effects that only cover the dance floor area. This can be done by positioning a fixture towards the dance floor, and recording this as a position palette. Then go to Effects, and apply the effect you wish to use. Adjust the Size parameter, to set the area the fixture moves over. You can then adjust the Speed to suit, and record this as an Effect palette. Hope that helps, any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Carpo Posted February 21, 2018 Author Report Posted February 21, 2018 Yes great - it make sense :-) Quote Carsten Poulsen Carpo Roadshow www.carpo.dk
