LP Posted February 14, 2018 Report Share Posted February 14, 2018 Hi everyone, is it possible to create macro’s witch control programmer time? My goal is to create some preset times to fade between palettes. thanks in advance, Wytse Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted February 14, 2018 Report Share Posted February 14, 2018 Hi Wytse, You wouldn't be able to set Programmer Time duration using Macros, as this is defined by using the Programmer Time fader. The other option available to you to achieve similar results is to use the Preset Time, rather than Programmer Time, as this will allow you to record a Macro. To do this, tap RECORD -> MACRO -> tap an empty Macro MFK -> Choose "Keys" -> SPECIAL -> Time MFK -> Type the Time you want -> ENTER -> MACRO. You will then have this Macro Recorded, so that you can set the Preset time to that level at the tap of the Macro MFK. You can reoeat this process to record several Preset Time Macros. Now when you press and hold the TIME button and press the Palette you want to fade to, you will fade into it over your Preset Time. Hope that helps, any queries let me know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
