go4more Posted February 5, 2018 Report Posted February 5, 2018 I'm struggling running playbacks in sequence. Having used the Fat Frogs when I moved to another page the sub master would flash to indicate it was still live for a cross fade between subs. I find on my Solution is Playback 10 is live and I move to page 2 to bring up Playback 11 I have to jump back a page to fade out Playback 10 Could you advise what I doing wrong please and if there are any fixes I could use? Regards Chris Quote
kgallen Posted February 6, 2018 Report Posted February 6, 2018 There is a "Page Holdover" function. Probably within the Setup+Playback-button settings or maybe the general Setup. I think it's the same question as this one in the FLX forum: Quote
Edward Z88 Posted February 6, 2018 Report Posted February 6, 2018 Hi Chris, Yes Kevin is correct. For your Playbacks on your Solution to act like a Fat Frog, tap SETUP -> System Settings -> Page Holdover if Active set to Enabled. Hope that helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
go4more Posted February 6, 2018 Author Report Posted February 6, 2018 Super - Many thanks, got it! Regards Chris Quote
