Unexplained option in setup -> System settings -> Page Holdover if Active
I think it means that if a playback is active (MFF is up), then if you change playbacks page, that MFF continues to function as per the original playback page. When you release that playback, the MFF will then move to relate to the current page.
Kevin
Hi Kevin,
This sounds reasonable to me. Another great possibility if your correct, but in my opinion this then should be an option in the MFF playback setup to have this as a "per fader decission".
Regards,
Edi
