Hi all,
I have an ML24 with a dead backlight on the main display. It's not the end of the world because I can still see the text when the ambient lighting is bright but in a theatre scenario its a bit of a pain. Are they easy to fix? My background is electronic engineering so if its a part swap-out then I can do that.
6 hours ago, Onefff said:
Hi all,
Sounds like the display PCB will need replacing. Drop us an email at support@zero88.com and we will be able to get things sorted for you.
