brian hutchison Posted January 20, 2018 Report Share Posted January 20, 2018 Hi! A really useful feature for use in venues would be "template files", i.e. read-only show files which can't be (easily) edited, just loaded and then saved with a different name as a normal showfile. This allows the desk to easily be set to a clean starting state without relying on keeping a file on an external stick or user discipline. Alternatively, if I've missed a way to do this already it'd be good to know! Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted January 22, 2018 Report Share Posted January 22, 2018 Hi Brian, Thanks very much for the request. I have logged this on our software tracking system as feature request ZOS-8425. Currently a similar way to do this is to load in "Setup & Palettes", which allows you to just load in those parts of a show file, and leave the rest of the console empty ready for programming. Hope that helps Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Jon Hole Posted January 30, 2018 Report Share Posted January 30, 2018 Hi Brian, We've experimented with the idea of a "default" showfile - a specific file you could easily load (but not quite so easily overwrite - perhaps requiring a code). This was initially for an internal purpose (for use during tradeshows to revert consoles back to a default state), however it could also be useful for situations like this. This would probably be listed under the "Source" dropdown - so you have the USB devices, and a "Default showfile" section. Thoughts? Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
