Guest Nick Posted January 17, 2018 Report Posted January 17, 2018 Hello, I am interested in buying a Zero88 FLX 24 but I heard that there is no overall master fader, only a playback master, will that be assignable as a master fader in the future? Quote
Edward Z88 Posted January 17, 2018 Report Posted January 17, 2018 Hi Nick, The 24 faders on the left hand side of the console can either be channels, or what we call "Playbacks". You can assign any of these Playbacks, plus the Master Playback fader under the touchscreen to be what we call a "Grand Master" fader, which allows you to control the overall output of the console. Hope that helps, any queries let me know Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Guest Steve Posted January 26, 2018 Report Posted January 26, 2018 How do you assign the master play back fader to act as grand master? i cannot seem to figure that out. also i cannot figure out how to go to blackout. Quote
Edward Z88 Posted January 26, 2018 Report Posted January 26, 2018 2 hours ago, Guest Steve said: How do you assign the master play back fader to act as grand master? i cannot seem to figure that out. also i cannot figure out how to go to blackout. Hi Steve, If you haven't recorded anything onto the Master Playback, hold SETUP and tap the Master Playback's GO button. You will then be able to choose "Grand Master". The fader will then act as the Grand Master, and the Master Playback's button will act as a Blackout. Hope that helps, any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Guest Steve Posted January 29, 2018 Report Posted January 29, 2018 Thanks very much for that much appreciated. Quote
Guest Nick Posted January 30, 2018 Report Posted January 30, 2018 I have another question about the FLX but I'm not sure how to formulate it so opening a new topic with a very confusing title wouldn't be the best idea. We still would like to buy a FLX 24 and we also want to invest in some more led fixtures but that might be a problem for technicians that bring their own console. Is it possible to keep the FLX in the chain, using a DMX merger, for choosing the colors and zoom etc for the fixtures and to patch it, so the guest technician can patch as if he's patching conventional lights, so he only controls the intensity. I hope the above makes some sense and someone can answer the question. Quote
Edward Z88 Posted January 30, 2018 Report Posted January 30, 2018 Hi Nick, Yes that is possible, depending on your fixtures and the merge that you use. Is there any reason the Guest Technician wouldn't use the FLX S? Keeping one control console always makes things easier, and if the guest technician wants to use the console and just control intensities you could always use the Remote App to control the colour and zoom remotely, whilst they stick to controlling intensities. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Guest Nick Posted January 30, 2018 Report Posted January 30, 2018 Well, I'm talking about a small theatre setting so sometimes people take their own console with the show already programmed, all they have to do is patch the fixtures and check the intensities, but most shows are still made on conventional lights so it would be handy to tell them patching won't be too much of a hassle because of the led fixtures in our theatre Quote
Jon Hole Posted August 31, 2018 Report Posted August 31, 2018 Split conversation - other posts can be found here: Quote Jon Hole linkedin.com/in/jonhole
OSF Posted November 6, 2018 Report Posted November 6, 2018 On 1/26/2018 at 2:25 PM, Edward- Z88 said: Hi Steve, If you haven't recorded anything onto the Master Playback, hold SETUP and tap the Master Playback's GO button. You will then be able to choose "Grand Master". The fader will then act as the Grand Master, and the Master Playback's button will act as a Blackout. Hope that helps, any queries let me know. Edward Edward, I tried this, but I do not see a "Grand Master" option anywhere to be able to accept it. Forgive me, I am a complete newb. Also if I suceed ingetting this to work will the GM and blackout function work regardless of whether I am in Channels or Playback mode i.e. will it override everything else? Quote
Edward Z88 Posted November 6, 2018 Report Posted November 6, 2018 Hello, If you are not seeing an option for Grand Master when you enter the Master Playback's settings, tap DELETE -> then tap the Master Playback's button. You can then hold SETUP and tap its button, and in these special settings displayed on the internal touchscreen you should see an option for Grand Master. Choose this, and click OK. When using the Master Playback for a Grand Master and Blackout, you will be able to use it to control the overall intensity of the console regardless of whether you're in Channels or Playbacks fader function. Hope that helps, any queries let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
LisaEkbom Posted January 16, 2019 Report Posted January 16, 2019 If i already have my whole show recorded on the Master Playback, can I still change it to Grand Master? Quote
Edward Z88 Posted January 16, 2019 Report Posted January 16, 2019 Hi LisaEkbom, Any empty playback can be configured to be a Grand Master, it doesn’t have to be the Master Playback. If you’d like the Master Playback to be a Grand Master, copy your existing playback to an empty playback by tapping Z/Shift -> Copy -> Tap the Master Playback -> Tap a flashing empty playback to copy to. Then tap DELETE -> tap your Master Playback, then hold SETUP + tap your Master Playback. You can then choose Grand Master from the options and click OK. To go back and view your cue stack again, hold VIEW and tap the Playback button you copied to. If you don’t feel confident deleting playbacks, make sure you save a copy of your show first to a USB stick, then if you Delete the wrong playback you can simply load your show file back in. Hope this helps Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Michaelm Posted February 1, 2019 Report Posted February 1, 2019 On 11/6/2018 at 12:42 PM, Edward- Z88 said: Hello, If you are not seeing an option for Grand Master when you enter the Master Playback's settings, tap DELETE -> then tap the Master Playback's button. You can then hold SETUP and tap its button, and in these special settings displayed on the internal touchscreen you should see an option for Grand Master. Choose this, and click OK. When using the Master Playback for a Grand Master and Blackout, you will be able to use it to control the overall intensity of the console regardless of whether you're in Channels or Playbacks fader function. Hope that helps, any queries let me know. Edward Hiya how do you assign one of 24 normal playbacks to become a grand master? Thanks michael Quote
Edward Z88 Posted February 1, 2019 Report Posted February 1, 2019 Hi Michael, You can assign these to be a Grand Master in exactly the same way as assigning the Master Playback - hold SETUP and tap an empty Playback’s button, and from the options choose Grand Master. Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Michaelm Posted February 1, 2019 Report Posted February 1, 2019 2 hours ago, Edward- Z88 said: Hi Michael, You can assign these to be a Grand Master in exactly the same way as assigning the Master Playback - hold SETUP and tap an empty Playback’s button, and from the options choose Grand Master. Hope this helps, Edward Hi Edward that’s fantastic thank you. Michael Quote
Edward Z88 Posted February 1, 2019 Report Posted February 1, 2019 6 hours ago, Michaelm said: Hi Edward that’s fantastic thank you. Michael No problem, let me know if there’s anything else I can help with. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Rob72 Posted November 26, 2022 Report Posted November 26, 2022 sorry, read this topic but still do not understand: i would like to assign masterfader function to fader 24 on flx24s in channel mode (so not use the masterplaback fader nor the fader 24 in playbak mode) is this possible? Quote
kgallen Posted November 26, 2022 Report Posted November 26, 2022 You can't assign the Grand Master function to a MFF in Channel mode, the MFFs need to be in Playbacks mode. In Channel mode, fader 24 will always be the intensity/trigger for fixture 24. The way to configure an MFF in Playbacks mode is "Setup + Playback button" (then select Grand Master), noting that the Playback needs to be unprogrammed to get those options. 1 Quote
Dave Quinn Posted July 6, 2023 Report Posted July 6, 2023 Is there a way of “parking” channels or playbacks on the S24/ 48 like the FLX? I would like to be able to fade my master fader for a blackout but leave some channels sending control data to the house lights unaffected? Quote
Jon Hole Posted July 6, 2023 Report Posted July 6, 2023 There isn’t, but you could probably achieve the same using Inhibit Playbacks - essentially creating a Grand Master of just some channels? Quote Jon Hole linkedin.com/in/jonhole
