Hi Peachy,
Thanks for letting us know. We haven’t come across anyone else with this issue. However it sounds as if your SunStrips are not truly DMX compliant, and are receiving the RDM protocol used by RigSync and trying to interpret it as DMX data, which you’re seeing as a flicker.
If you wish to use the SunStrips on the same DMX Output that has RigSync enabled, try addressing them to a DMX address in the second half of the universe (for example DMX 256-512) as this may stop the flickering.
Kind regards
Hi Edward,
Yes it seems even though these are the newer MK2, Highlite haven't included RDM.
It's not really a big problem, just gave me a bit of scare when we upgraded to the new version of ZerOS and all the SunStrips started pulsing every few minutes.
