replacement buttons for fat frog
jesterfish
The switch mechanism is still available as a spare from Zero88, so you should be able to order from your local Zero88 Dealer or from a Zero88 parts supplier *coughs*.
Each mechanism comes complete with the cap so you don't need to faff swapping that but the LED's aren't  interchangeable as they're embedded in the mechanism case.
From experience - it takes about 20 minutes to desolder/solder the button mechanism in place once you've opened the case - if you've not changed the battery in the desk for a while, do that whilst it's open.
