jesterfish Posted December 28, 2017 Report Posted December 28, 2017 Hi. my hard working fat frog is getting tired the outputs toggle swith/button and fixture button 2 toggle / swith have failed and i am looking to replace them is there somwhere i can contact to get new / good second hand replacements Thanks Richard Quote
iank99 Posted December 29, 2017 Report Posted December 29, 2017 The switch mechanism is still available as a spare from Zero88, so you should be able to order from your local Zero88 Dealer or from a Zero88 parts supplier *coughs*. Each mechanism comes complete with the cap so you don't need to faff swapping that but the LED's aren't interchangeable as they're embedded in the mechanism case. From experience - it takes about 20 minutes to desolder/solder the button mechanism in place once you've opened the case - if you've not changed the battery in the desk for a while, do that whilst it's open. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk
