W914P Posted December 26, 2017 Report Posted December 26, 2017 Wer kann mir einen Tipp geben, warum nach der Installation einer Moving Head Fixtur nicht alle Effekte wie z.B. Kreis,Acht usw. aktiv sind bzw. reagieren. Gruß WP Quote
keredyelesob Posted December 27, 2017 Report Posted December 27, 2017 Hi. Try to recreate the effects pallets. This should fix the issues. What console are you using and what version of Zeros are you using? Quote
Edward Z88 Posted December 27, 2017 Report Posted December 27, 2017 Hello, Yes as suggested tap “Create Effects Palettes” again. This can be done on Solution by tapping EFFECT, and then page down on the MFKs to get to the last page, and you should find the Create Palettes MFK. These effect palettes are then compatible with your new fixtures. Hope that helps Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
W914P Posted December 27, 2017 Author Report Posted December 27, 2017 Ich möchte mich für den Tipp Recht herzlich bedanken, werde das nächste Woche probieren, da die Anlage zu.Zeit umgebaut wird. Zu der Frage welche Konsole :es ist die Solution nicht die XL und es wir die vorletzte Software aus 2016 verwendet. Nochmals grosses Dankeschön, Gruß Wolfgang Quote
TylerHolpin Posted January 2, 2018 Report Posted January 2, 2018 Hello, Hopefully you have had chance to check what Edward suggested for your to do. Regarding the software version, we would highly recommend updating to 7.9.3 which was released in the later parts of 2017. You can download it from the downloads tab at the top of the forum. Many thanks, Tyler Quote
