Yes as suggested tap “Create Effects Palettes” again. This can be done on Solution by tapping EFFECT, and then page down on the MFKs to get to the last page, and you should find the Create Palettes MFK. These effect palettes are then compatible with your new fixtures.
Hope that helps
Product Specialist
Email Support
Ich möchte mich für den Tipp Recht herzlich bedanken, werde das nächste Woche probieren, da die Anlage zu.Zeit umgebaut wird. Zu der Frage welche Konsole :es ist die Solution nicht die XL und es wir die vorletzte Software aus 2016 verwendet.
Nochmals grosses Dankeschön, Gruß Wolfgang
Hopefully you have had chance to check what Edward suggested for your to do.
Regarding the software version, we would highly recommend updating to 7.9.3 which was released in the later parts of 2017. You can download it from the downloads tab at the top of the forum.
Many thanks,
Tyler
