Primax98 Posted December 8, 2017 Report Posted December 8, 2017 When using moving heads and effect is there an east way to change the direction ??? Quote
Edward Z88 Posted December 8, 2017 Report Posted December 8, 2017 Hello, To change the direction of an effect dial the "Speed" wheel down, and you will find it goes into negative values, which means the effect direction is reversed. Hope that helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
