thierry Posted December 6, 2017 Report Posted December 6, 2017 Hello everybody, I've created a simple chase (4 linealed ,colour white, 4 cues in one playback, bounce 1234321). So far so good... I want to change the colour without "re"-creating the chase... I run my playback where the chase is stored, then i select my 4 linearled, i choose the new colour (for ex: red) from a palette, then i push the "update" button and the "update windows " appears... At this point i need help because i've tried all the options but never got it working ( excepting if it's a single cue in a single playback, but in a playback turned into a chase... nothing) Sure i'm doing something wrong, but what ? Quote
Edward Z88 Posted December 6, 2017 Report Posted December 6, 2017 Hi Thierry, To update a cue/step of chase, you need to go into it using GO Snap. You can do this by holding SHIFT + tapping the chase's button. You will find that rather than acting as a tap tempo, it now acts a GO Snap and pauses the chase from running. This allows you to go to the step you need to edit, make your changes, tap UPDATE, and then tap the chase's button. You can then tap the chase's button again and the chase will resume to run automatically. Hope that helps, any queries let me know Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
thierry Posted December 6, 2017 Author Report Posted December 6, 2017 Hi Edward, Everything worked fine, thank you. I just thought that it was possible to make that kind of change in one time, but it seems that we must consider all the steps of the chase " step by step"... Okay Quote
Edward Z88 Posted December 6, 2017 Report Posted December 6, 2017 Hi Thierry, Great, yes when editing a chase you can treat it as a normal cue list, and usual tracking rules will apply. Kind regards Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
thierry Posted December 6, 2017 Author Report Posted December 6, 2017 Quote Another question, is it possible to merge 2 chases (in two different playbacks) by running them and recording them in another third playback (so far i didn't found how to...) Quote
Edward Z88 Posted December 6, 2017 Report Posted December 6, 2017 Hi Thierry, I think how I would do this is program a completely blank cue onto a Playback, and in that cue have 2 trigger macros for both chases. This Trigger Playback can then be raised and trigger both chases simultaneously. You would then need to record a second blank cue containing two release macros in the following cue, as lowering the trigger playback wouldn't release the chases automatically. Hope that helps, Kind regards Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
ziglight Posted December 6, 2017 Report Posted December 6, 2017 Hello Thierry je vais te répondre en français; ce sera plus simple ! quand tu enregistres une cue-list dans un playback (par exemple pour en faire un chase); il y a deux façons de faire et cela décide comment l'édition se fera ensuite première façon : quand tu es en Smart Tag (Basic Tracking), dans chaque Cue sont enregistré tous les paramètres d'attributs que tu vois (en somme tout ce qui n'as pas une valeur de "zéro"); exemple la couleur blanche est enregistré dans chacune de tes Cues quand tu veux changer ton chase ensuite en rouge il faut donc éditer chaque Cue indépendamment l'autre façon est par Tracking Advanced : dans ce cas tout les paramètres (et attributs) visibles sont enregistré dans la première Cue et ensuite, dans les autres Cues sont enregistré seulement les changements (exemple intensité pour les chase ou "position" pour les movers etc) => exemple tant que tu ne changes pas la couleur rien n'est enregistré pour l'attribut couleur dès la deuxième Cue en conséquence quand tu as enregistré une Cue-List en "Tracking Advanced", il suffit ensuite d'éditer seulement la première Cue (ou celle à partir de laquelle tu veux que ça change) pour que ce changement (exemple couleur en rouge) se perpétue dans toutes les autres Cues qui viennent après jusqu'àce qu'il y a un nouveau changement de valeur d'attribut enregistré (exemple couleur blanche ou bleu etc) j'espère que l'explication est assez clair ?! note aussi : si tu as enregistré tout un Stack (Cue-List ou Chase) déjà en Smart-Tag (ou Basic Tracking) tu pourras (encore) changer en éditant les diverses Cues et en enlevant les tags de tracking pour les attributes qui ne changent pas d'une Cue à l'autre (enlever le Tag de l'attribut Color dans ton cas) dans ce cas tu récupères le tracking-forward qui pourra éventuellement te faciliter la vie plus tard (pour d'éventuelles éditions) enfin il s'agit simplement d'utiliser une méthode de travail ou une autres, adaptée à tes besoins... (ça n'est pas une question bon ou pas bon) Quote
Edward Z88 Posted December 6, 2017 Report Posted December 6, 2017 Hi Ziglight, Just to clarify, SmartTag is still tracking, and will Record the changes of fixtures, however will also automatically tag parameters that have changed from the previous cue, or intensities that are above 0% from a different source. It will also ignore parameters of a fixture with an intensity of 0%. Therefore in your example, with SmartTag enabled you could update the first cue and all subsequent cues will have changed colour, until there was another colour change. The way you described was non-tracking/ Cue Only. Tracking can be enabled/disabled from SETUP -> System Settings Juste pour clarifier, SmartTag est toujours suivi, et enregistrera les changements d'appareils, mais marquera aussi automatiquement les paramètres qui ont changé de la cue précédente. Il ignorera également les paramètres d'un appareil avec une intensité de 0%. Par conséquent, dans votre exemple, avec SmartTag activé, vous pouvez mettre à jour le premier repère et tous les repères suivants auront changé de couleur, jusqu'à ce qu'il y ait un autre changement de couleur. La façon dont vous avez décrit était non-suivi. Le suivi peut être activé / désactivé depuis SETUP -> Paramètres système Hope that helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
thierry Posted December 6, 2017 Author Report Posted December 6, 2017 Salut Ziglight, merci pour ton aide, tes explications sont assez claires, c'est le mode de fonctionnement de la console qui ne l'est pas... J'essaie juste de façon empirique de comprendre comment les menus fonctionnent et à quoi ils me mènent en mémorisant des scènes. Pour l'utilisation "congrès" que j'en ai, ce que je sais faire avec la SolutionXL est très largement suffisant , d'autant plus que je ne suis pas "electro" dédié car je gère plein d'autres choses en parallèle sur une presta (vidéo, infographie..). Mais comme je suis curieux, par principe, et pour avoir du répondant en cas d'accueil d'un gars (ou d'une fille) sur la machine, et ne pas passer pour une truffe, j'essaie lors du temps libre (je suis permanent et le light reste mon poste préféré) de faire tourner un peu des trucs de façon à pouvoir être réactif (et un peu créatif de temps en temps...). Ma config est de 4 lyres Robes Robin600e, 16 par led rgbw linearled, 10 plcyc2 selecon, le reste traditonnel en pc/découpes/cycliodes ADB & Juliat Le traditionnel pour les wash plateau et ponctuels, les leds et lyres pour la déco, le tout géré en pages de playbacks en live, je ne suis pas adepte des conduites car de toute façon ce n'est pas adapté aux évènements que nous accueillons. - créations de cues : no problem - rec de cue (ou multi cues) sur playback : no problem - manip de lyres (malgrés la non ergonomie) : no problem J'arrive à peu près à faire ce que je veux mais c'est dans les enchainements que ça se gâte ( tag, pas tag, rouge/vert à cocher dans les menus Record & Update), il faut que je m'y colle un peu plus. Je commence à patauger dans le menu "update" pour savoir quoi cocher ou décocher (en rouge) pour arriver à mes fins (en l'occurrence, quand j'essaie le fameux update de couleur sur mon chase, les cues et la palette couleur sont bien dans des cases à cocher ou pas) mais comme Edward et toi même dites qu'il faut l'éditer pas à pas, je comprends et je le fais, ça marche. Ce qui m'induit en erreur tout le temps c'est de tomber sur des menus fenêtrés qui laissent à penser que la manœuvre est possible alors qu'en fait ça ne l'est pas. Si on ne peux pas éditer globalement un playback contenant un chase, alors pourquoi la touche update nous fait croire le contraire ? Quote
ziglight Posted December 6, 2017 Report Posted December 6, 2017 Hello Thierry avant tout : j'espère que tu es déjà en mode trackin (et non pas en mode : "NON TRACKING" ensuite, comme j'ai dit plus haut : une fois qu'une Cue-List est enregistré d'une façon ou d'une autre le comportement de tracking est enregistré avec tu peux changer ce comportement d'enregistrement, comme je l'ai décrit plus haut dans la page "Special" activer Smart-Tag (Basic Tracking) ou le desactiver (Tracking Advanced); le menu d' UPDATE intervient évidemment plus tard lors de l'édition; mais il faut éditer dans chacune des Cues si auparavent tu as enregistré sous "Smart-Tag" le menu d'UPDATE (Tracking Forward ou Backward, Cue only etc etc) sera le plus efficace si ta Cue-List (ou ton Chase) est préalablement enregistré en mode Full-Tracking (= Tracking Advanced) => tu dois donc tout d'abord désactiver Smart-Tag pour commencer ! (attention car le Full-Trackin inclus d'autres pièges car ce mode n'enregistre pas ce que tu vois mais seulement ce qui a été taggé auparavent !! => mais on parle du fonctionnement tout à fait normale et "voulue" de la console; faut juste comprendre comment ça fonctionne...! Dond ce n'est pas du tout que le menu UPDATE est inactif mais c'est que ton mode d'enregistrement (le Smart-Tag) fait que certains de tes selections sont annulé par le mode Smart-Tag (en l'occurrence tous ce qui n'est pas à zéro est automatiquement taggé et enregistré !!) va en mode Full-Tracking et fais quelques essais et tu verras peut-être plus facilement ce que je veux dire !! bonne chance bien cordialement Ziggy Quote
thierry Posted December 6, 2017 Author Report Posted December 6, 2017 Merci, c'est ce que j'ai toujours pensé, faut se mettre en "Tracking Advanced" pour garder la main sur tout. Faut faire plus attention à ce qu'on fait, mais au moins tout est plus clair. Bon ben je m'y recolle demain, je vais tout faire bouger et clignoter dans tous les sens... Cordialement, Thierry Quote
