Thomas Haaser Posted December 18, 2017 Report Posted December 18, 2017 On 7.12.2017 at 7:38 PM, Jon Hole said: 270/5000 Hellothe all video's are very nice.I have a question. Is this function programmer time work´s for all consoles.I know that the Solution series works by holding down the Time key.What about the ORB series, FLX S series?Thank you for your answerBest regards Quote
Edward Z88 Posted December 19, 2017 Report Posted December 19, 2017 Hi Thomas, Yes Programmer Time is available on all consoles running ZerOS 7.9.3. Solution & ORB therefore have 2 methods of fading palettes, using a Playback to set the Programmer Time, or if you don't want to use a Playback holding TIME and tapping the palette you want to fade into. As you say this time for Solution consoles is set under SPECIAL, which is the same time the 2 preset cross fade uses. Hope that helps Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
stowedout Posted December 19, 2017 Report Posted December 19, 2017 Well done guys these are excellent. I'm hooked now. Can't wait for "Mixing cocktails using the gobo shake function on my movers and a UDK" Happy Christmas Chris Quote
Edward Z88 Posted December 19, 2017 Report Posted December 19, 2017 Hi Chris, Glad you like the videos! 22 minutes ago, stowedout said: Can't wait for "Mixing cocktails using the gobo shake function on my movers and a UDK" How did you know about what video is lined up for Christmas Day?! Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Thomas Haaser Posted December 19, 2017 Report Posted December 19, 2017 12 hours ago, Edward- Z88 said: Hi Thomas, Yes Programmer Time is available on all consoles running ZerOS 7.9.3. Solution & ORB therefore have 2 methods of fading palettes, using a Playback to set the Programmer Time, or if you don't want to use a Playback holding TIME and tapping the palette you want to fade into. As you say this time for Solution consoles is set under SPECIAL, which is the same time the 2 preset cross fade uses. Hope that helps Edward Hi Edward Thank you for your answer.I only tested it on the Phantom ZeroOS.With the solution I set up the Programmer Time function with Setup + Playback. There is no change to the Programmer Time! I see no changes in the lower right corner of the screen.Keeping the Time button works well.Orb changes are made to the Playback Programmer Time.I see changes in the lower right corner of the screen.When calling the palette, there is no fade!Keeping the Time button works well.I hope you understand me. What am I doing wrong?Thomas Quote
Edward Z88 Posted December 20, 2017 Report Posted December 20, 2017 Hi Thomas, On Solution, the display in the bottom right corner is the 2-Preset Time (the same time palettes take when TIME is held) set under Special, not the Programmer Time. To see the Programmer Time tap SUBMASTERS and you'll be able to see the Programmer Time playback's position in seconds or minutes. To activate programmer time you'll need to tap the Playback's button. You will then see it go from dark to light blue in the MFF Window. Again on ORB Series, check that you've tapped the Programmer Time Playback's button to activate it. This is indicated in the bottom right monitor display which will go red, and also shown in the MFF Window on ORB XF. You can open the MFF window by holding SHIFT + FADER FUNC. Hope that helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Guest Thomas Haaser Posted December 20, 2017 Report Posted December 20, 2017 5 hours ago, Edward- Z88 said: Hi Thomas, On Solution, the display in the bottom right corner is the 2-Preset Time (the same time palettes take when TIME is held) set under Special, not the Programmer Time. To see the Programmer Time tap SUBMASTERS and you'll be able to see the Programmer Time playback's position in seconds or minutes. To activate programmer time you'll need to tap the Playback's button. You will then see it go from dark to light blue in the MFF Window. Again on ORB Series, check that you've tapped the Programmer Time Playback's button to activate it. This is indicated in the bottom right monitor display which will go red, and also shown in the MFF Window on ORB XF. You can open the MFF window by holding SHIFT + FADER FUNC. Hope that helps, Edward Thank you! It's fun to work with that knowledge.Which Relase Notes or user manual is it written?Should it again be a completely revised version of the manual to all consoles?best regardsThomas Quote
Jon Hole Posted December 20, 2017 Author Report Posted December 20, 2017 Quote Jon Hole linkedin.com/in/jonhole
Jon Hole Posted December 22, 2017 Author Report Posted December 22, 2017 Quote Jon Hole linkedin.com/in/jonhole
kgallen Posted December 26, 2017 Report Posted December 26, 2017 ....and to end these advacan-advacan-advacan-advacanada videos... we'll do it all again next year... ! ...oh this is all just taking too long...! Quote
Jason Brameld Posted January 2, 2018 Report Posted January 2, 2018 These were great and very helpful - thanks. Two suggestions/comments - 1: Sometimes we can't see what you're pointing at/changing on the monitor screen or on the desk touchpanel. 2: Fancy editing them together without the top and tail christmassy music to produce a great 'hints and tips' as a single video? That would be great as watching them all sequentially gets like Chinese water torture with the music! Keep up the good work. Jason. Quote
kgallen Posted January 26, 2018 Report Posted January 26, 2018 Are you boys working on the "Easter Egg Calendar" yet? We need a regular "fix" now you know. Tyler will be able to have an egggggg..ggg.ggg...cellent time making them. Quote
Jon Hole Posted January 30, 2018 Author Report Posted January 30, 2018 On 02/01/2018 at 8:08 PM, Jason Brameld said: Two suggestions/comments - 1: Sometimes we can't see what you're pointing at/changing on the monitor screen or on the desk touchpanel. Hi Jason, thanks for the feedback, sorry for my delay in replying! Hopefully it's a little clearer on the "official" FLX training videos - we'll keep an eye on this for any future videos we do. 2: Fancy editing them together without the top and tail christmassy music to produce a great 'hints and tips' as a single video? That would be great as watching them all sequentially gets like Chinese water torture with the music! We no longer have all the original files, so we can't take the background music out, but we may be able to cut them together so we get rid of the loud bits at the beginning and the end! On 26/01/2018 at 2:49 PM, kgallen said: Are you boys working on the "Easter Egg Calendar" yet? We need a regular "fix" now you know. Tyler will be able to have an egggggg..ggg.ggg...cellent time making them. We're not, we've been having fun doing something completely different instead: Quote Jon Hole linkedin.com/in/jonhole
Jason Brameld Posted January 30, 2018 Report Posted January 30, 2018 That looks like much more fun! Quote
kgallen Posted January 30, 2018 Report Posted January 30, 2018 3 hours ago, Jon Hole said: We're not, we've been having fun doing something completely different instead: Hey, that was the last FLX t-shirt that you promised to me, you just sent to get irradiated! Quote
Sven76 Posted December 7, 2018 Report Posted December 7, 2018 No Advent Calenda this year? 😢 Quote
Jon Hole Posted December 7, 2018 Author Report Posted December 7, 2018 2 hours ago, Sven76 said: No Advent Calenda this year? 😢 We've been up to something else on Facebook and Twitter this year - take a look! Quote Jon Hole linkedin.com/in/jonhole
