Uriahdemon Posted October 11, 2017 Report Posted October 11, 2017 I have read the manual and it mentions offset however does not explain what it does. Can anyone help please...?? Quote
Edward Z88 Posted October 11, 2017 Report Posted October 11, 2017 Hi Mac, Offset is used to fan and spread effects across lights. If you have multiple lights selected running an effect, and dial the offset wheel you will see no change to your lights. This is because you would be offsetting each light by the same amount, therefore they continue doing the same thing. For the Offset encoder to act as a "Fan", you'll need to hold SHIFT as you dial the Offset Encoder. To change how the Offset wheel behaves when you hold SHIFT, hold SETUP and tap the EFFECT button. Then hold SHIFT, and you will see the red stripe on the Wheel Behavior buttons change. You can then keep shift held and select Fan Middle" for example, OK the window, and now when you hold SHIFT and dial the offset your selected fixtures will all fan middle. In ZerOS 7.9.3 planned to be released within the next few weeks dedicated Offset buttons are provided along the top of the Effects Palette window to allow you to quickly fan effects across your lights. Hope that helps, any queries let me know. Kind regards Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Uriahdemon Posted October 11, 2017 Author Report Posted October 11, 2017 Thanks Ed, I will have a play with that later. Quote
AshA101 Posted October 23, 2017 Report Posted October 23, 2017 Quote In ZerOS 7.9.3 planned to be released within the next few weeks dedicated Offset buttons are provided along the top of the Effects Palette window to allow you to quickly fan effects across your lights. Expand Interesting! Looking forward to seeing what other changes have been made. Quote
