jaymason96 Posted September 14, 2017 Report Posted September 14, 2017 Hi, I had error 003 and followed instructions on here to replace the battery in the PCB. Now when I turn the desk on I see Error 001 NO Presets PCB Data 000 Count 002. The desk won't let me do anything from there. I read that the ribbons may be disconnected or the dipswitches incorrectly set - the ribbons are firmly in so I think it's the dipswitches but I can't find any info on how they should be set or what they do. Please help if you can as at the moment I have no LX desk Thanks Quote
iank99 Posted September 15, 2017 Report Posted September 15, 2017 Here you go - see if this helps... If the front panel is responding e.g. the cursor keys and mode select buttons - then try getting in to Super User and resetting the desk - this will hopefully get it back and working for you. If the front panel isn't responding then there is likely to be a more fundamental problem with the processor board or the front board and you'll need to get a Zero88 Approved Technician to look at it for you. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk
jaymason96 Posted September 21, 2017 Author Report Posted September 21, 2017 That worked. Thanks! Quote
