How do I go about updating a cue in a cue list which is made entirely of auto cues, I can't get to the one cue I need to update because, well it just runs through the cue list automatically. Is there a way to load the cue into the programmer, I know you can pause the main stack but this isn't helpful because unless you get it just right it'll pause mid way through a fade time.
Hi AshA101,
There are two options. The easiest (and the one I use) is SHIFT + GO acts as a "snap" (ignoring fade times) and also ignores the auto cues. This then allows you to update the cue. If this doesn't work, the default settings have changed - go into the Playback Settings (SETUP+GO) to change the shifted mode of the GO button.
The other option is to enter Blind (select "Blind" in the Output Window, or press SHIFT+Z), and then load the cue into the Blind Programmer (hold the GO button, type the Cue Number, and then release the GO button), make the updates you wish and press UPDATE ENTER.
Jon Hole
