Hi Simon,
Currently you can do this when Highlight is active. To do that select a light, hold SHIFT + tap HOME, and you can then use the Left/Right arrow keys to move to the next/previous fixture.
In the next software release coming soon holding SHIFT + pressing Left/Right arrow keys will select the next/previous fixtures without highlight being active.
Hope that helps
Kind regards
