a_user_JPN Posted August 17, 2017 Report Share Posted August 17, 2017 Hello, I'd like to know how to solve a problem concerned with Playbacks. I've attached a Showfile with this problem. Playback 49 is programmed to show only "Red" up to 100%, and Playback 50 contains 100% of "Red" and 47% of "Green" to show "Orange". Raising Playback 49 first, then raising Playback 50. After that, lowering Playback 49 and 50 sequentially will cut out Red. I'd like to know how I can set up Playback 50 to fade out the colour. Best regards 0817.isf Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted August 17, 2017 Report Share Posted August 17, 2017 Hello, I've had a play with your showfile and this looks to be a software issue- we will look into fixing this (reference ZOS-8046). To avoid this issue, what I would recommend is (double press CLEAR) raising only Playback 50 and selecting channels 25>31. Press COLOUR, tap the screen above the first encoder which says "Red" and you should see "Tag [Red]" come in the command line. Then press UPDATE, select "Remove" from the Update Option window (press and hold Update so that it comes in the internal monitor), then Press Playback 50's button. This means you just have 47% green on this fader and have removed the red, and so now to create your green you just leave both Playback 49 and 50 up, and then when you want to fade the Orange out pull down both faders. Hope that helps, any queries let me know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
