mikeb Posted August 11, 2017 Report Posted August 11, 2017 Hi I knew in the older builds how to create a topset for dimmers and also how to software swap pan/tilt but where are these features in the 7.9.n builds on a Solution? Many thanks Mike Quote
Edward Z88 Posted August 12, 2017 Report Posted August 12, 2017 Hi Mike, As per ZerOS 7.9.2, these are set in tabs along the top of Edit Fixtures in SETUP. There is a dedicated tab for Topset, and Pan/Tilt Swap comes under the Alignment tab. Hope that helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
