Sarna1 Posted August 11, 2017 Report Share Posted August 11, 2017 I need help. What do I need to do to solve the Error code 004 on a Zero 88 Jester 24/48 Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted August 11, 2017 Report Share Posted August 11, 2017 Hello, Error 004 on a Jester most likely means the internal battery has died. Changing the battery in a Jester is a simple fix, and the battery's can be purchased in most hardware shops. If you're confident you can open up the Jester, it's a CR2032 coin battery to replace. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Sarna1 Posted August 11, 2017 Author Report Share Posted August 11, 2017 Thank you Edward, I will try this. Quote Link to comment Share on other sites More sharing options...
Sarna1 Posted August 11, 2017 Author Report Share Posted August 11, 2017 Edward, I have changed the battery and now it says error code 003 bad product, any advice? Quote Link to comment Share on other sites More sharing options...
iank99 Posted August 12, 2017 Report Share Posted August 12, 2017 Go in to Super User and reset the desk - the product code is "hard coded" in the flash memory and usually a reset forces it to be re-read and defaults set that should get rid of the message. The product code tells the mainboard which Jester variant chassis it's sat in... The product code isn't read at each power up to save time and save all the internal data for the desk being rewritten. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk Link to comment Share on other sites More sharing options...
Edward Z88 Posted August 12, 2017 Report Share Posted August 12, 2017 Thanks Ian, Yes after resetting the console this error message will clear and you will be back up and running. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
