Is there an easy way to create a transient dimmer effect with an offset across the rig. I can see how to do it for colour but am struggling with dimmer. An idiots guide would be great.
Hi Pinky,
To create this effect I would select my lights and set their intensity, and apply the "Smooth" Effect palette, and then dial the "Size" parameter down so the effect is just rippling around your set intensity value. You can then hold SHIFT + dial the Offset parameter encoder.
Remember if you hold SETUP + tap EFFECT you can change the behaviour of the encoder when you hold SHIFT (different Fan options).
