terryb Posted July 1, 2017 Report Posted July 1, 2017 Just getting to grips with my first big show on the TLXtra after using an ML24. Apart from the buttons being in the 'wrong' place all is going reasonably well! I am learning this desk as I go but the problem I am having is that after controlling a dimmer channel using the key pad and wheel and then controlling the brightness of a fixture again with the wheel, the dimmer channel remains controlled as well. I can't work out how to make the controller forget the dimmer when I move to a fixture. Probably missing something obvious here, I usually am, but it would be a great help to know where I am going wrong. Quote
Edward Z88 Posted July 2, 2017 Report Posted July 2, 2017 Hi Terry, After controlling your dimmer channel with the keypad/ wheel you have to press ENTER, then when you select your fixtures you will only adjust their intensity. Hope that helps Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
terryb Posted July 31, 2017 Author Report Posted July 31, 2017 Sorry for the delay in replying. Thank you for your reply, I did work it out eventually, exhaustion, as so often happens meant that I wasn't thinking correctly. I was impressed by the desk, I had 28 fixtures varying from movers to geysers to a projector dowser. Once I got it all up and running it was a joy. Thanks again. Terry Quote
Edward Z88 Posted August 1, 2017 Report Posted August 1, 2017 Sorry for the delay in replying. Thank you for your reply, I did work it out eventually, exhaustion, as so often happens meant that I wasn't thinking correctly. I was impressed by the desk, I had 28 fixtures varying from movers to geysers to a projector dowser. Once I got it all up and running it was a joy. Thanks again. Terry No worries glad you got it all up and running! Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
