helliott2007 Posted June 27, 2017 Report Posted June 27, 2017 Hi Guys, Sorry to be posting again but haven't used the desk very much since the update. When recording positions to subs, you cant record the position from a palette. I can only seem to do it it by manually setting where the lights are and then recording it. Any thoughts, Thanks, Harry Quote
Edward Z88 Posted June 27, 2017 Report Posted June 27, 2017 Hi Harry, You can't do this with SmartTag enabled. When recording just attribute palettes to "sub" Playbacks, tap SmartTag to turn it off before recording. This will record the Playback as expected. You can then tap it again to turn it back on after recording it. Hope that helps Edward Quote Edward Smith Product Specialist Email Support
helliott2007 Posted June 27, 2017 Author Report Posted June 27, 2017 Edward, Thank you very much! Thanks, Harry Quote
Jon Hole Posted July 1, 2017 Report Posted July 1, 2017 Just to confirm, this is by design and due to the way Smart Tag works - Smart Tag ignores all fixtures with 0% intensity Quote Jon Hole Global Product Manager, Systems and Control
