Hi Guys,
Sorry to be posting again but haven't used the desk very much since the update.
When recording positions to subs, you cant record the position from a palette. I can only seem to do it it by manually setting where the lights are and then recording it.
Any thoughts,
Thanks,
Harry
Hi Harry,
You can't do this with SmartTag enabled.
When recording just attribute palettes to "sub" Playbacks, tap SmartTag to turn it off before recording. This will record the Playback as expected.
You can then tap it again to turn it back on after recording it.
Hope that helps
