helliott2007 Posted June 26, 2017 Report Posted June 26, 2017 When Using Robe 600 spots on Orb XF Desk, How do you record the separate beam-shape perimeters so you can overlap prism and gobos. So when removing a gobo, it keeps the prism effect or visa versa? (This is using the beam shape pallets) Thanks, Harry Quote
Edward Z88 Posted June 26, 2017 Report Posted June 26, 2017 Hi Harry, To make sure your parameters are kept separate you need to make sure only the parameters you want recorded into your palettes are "Tagged". Parameters are tagged automatically when you adjust the encoders. To "Untag" parameters hold CLEAR + Jog the parameters' encoder wheel. You will notice it will go from having a White background to a blue background in the LCD above the encoder. Therefore you will need to record your Gobo position palette, and then untag the Gobo encoder, and then record your prism encoder. These will now be separated, and you can then make a separate palette for both of these with the Gobo/ Prism parameters back to default. This would mean you have a palette for Gobo In, one for Gobo Out, one for Prism In, one for Prism Out. Hope that helps Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
helliott2007 Posted June 26, 2017 Author Report Posted June 26, 2017 On 6/26/2017 at 12:09 PM, Edward- Z88 said: Hi Harry, To make sure your parameters are kept separate you need to make sure only the parameters you want recorded into your palettes are "Tagged". Parameters are tagged automatically when you adjust the encoders. To "Untag" parameters hold CLEAR + Jog the parameters' encoder wheel. You will notice it will go from having a White background to a blue background in the LCD above the encoder. Therefore you will need to record your Gobo position palette, and then untag the Gobo encoder, and then record your prism encoder. These will now be separated, and you can then make a separate palette for both of these with the Gobo/ Prism parameters back to default. This would mean you have a palette for Gobo In, one for Gobo Out, one for Prism In, one for Prism Out. Hope that helps Edward Edward, Awesome help! Thank you very much. Made my life a lot easier Thanks, Harry Quote
