veit Posted June 16, 2017 Report Share Posted June 16, 2017 Hi, I would like to trigger some of my CUEs from our show control software. Obviosly this would be possible over Midi with the Midi extension board. But I thought if there maybe is an other way, possibly over the network. Is there an API to controle the desk? Regards Veit Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 16, 2017 Report Share Posted June 16, 2017 Hello, Ways of remotely controlling Solution without a SMPTE/ MIDI Card are the Remote App for phones, tablet and PC, and also DMX In being assigned to Playbacks. MIDI is the ideal way of triggering cues from show control software using Show Control or Time-code protocols. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
veit Posted July 14, 2017 Author Report Share Posted July 14, 2017 Hi Edward, thanks for your reply. I already thought so, yust hoped I could implement it directly without additional components. But then I think I will get a MIDI Card for our next production. Veit Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted July 15, 2017 Report Share Posted July 15, 2017 Ok great, Instructions on how to fit it can be found here: http://zero88.com/support/index.php?/Knowledgebase/Article/View/359/0/leap-frog-48--96-smptemidicanremotes-upgrade-kit---fitting-instructions---issue-1-en You can purchase the card from your local distributor: http://zero88.com/distributors/uk/index.shtml Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
veit Posted December 3, 2017 Author Report Share Posted December 3, 2017 Hi Edward, We finally got our Midi card. But I have some problems using it. I was not able to trigger Cues with MIDI. I tried MSC and Midi timecode but nothing happened. I enabled MIDI TIMECODE and MSC in the input Output Settings and checkt divice ID and fps match. The Midi signal also seems to work. At least our audio console receives the signal. Is there any way to check if the Midi card works correct and if it receives Data? Veit Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted December 4, 2017 Report Share Posted December 4, 2017 Hi Veit, What device are you using to output MIDI from the computer? Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
veit Posted December 4, 2017 Author Report Share Posted December 4, 2017 Hi, We use a Tascam US 16x08 controlled with a Software called Show Cue System. And what I forgot to say, we just updated to ZerOS 7.9.2.50 because I read there would be MIDI Problems in previous versions. But the update did not change the behavior. Veit Quote Link to comment Share on other sites More sharing options...
