Uriahdemon Posted June 9, 2017 Report Posted June 9, 2017 Hi, I was wondering if anyone can advise if I can use Phantom OS (FLX) and Capture software on the same PC together.....?? Quote
Edward Z88 Posted June 9, 2017 Report Posted June 9, 2017 Hello, Yes you can, this guide will help you... Capture Instructions.pdf Any queries let me know Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Uriahdemon Posted June 11, 2017 Author Report Posted June 11, 2017 Hi Edward, I have loaded everything as guided in the capture instructions. I have had a couple of the shows playing but wanted to try out my own movers on a basic stage. I have built that in capture and only used two movers to learn with in the desk (FLX). when in the output window I select a fixture the correct fixture is highlighted in capture. So they seem to be talking in some way at least. Unfortunately when I bring the intensity up there is nothing in Capture i.e. beam but in the FLX Output window intensity is at 100%. Quote
Edward Z88 Posted June 12, 2017 Report Posted June 12, 2017 Hello, Go through and check that all data matches in both Capture and ZerOS. It sounds like you've got channel numbers correct, however you may not have DMX values matching or may have fixtures in the wrong mode. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Uriahdemon Posted June 12, 2017 Author Report Posted June 12, 2017 Hello, Go through and check that all data matches in both Capture and ZerOS. It sounds like you've got channel numbers correct, however you may not have DMX values matching or may have fixtures in the wrong mode. Edward Thanks..... how exactly do you appoint DMX addresses to fixtures in capture.....?? Quote
Edward Z88 Posted June 12, 2017 Report Posted June 12, 2017 Page 26 in the Capture manual talks you through the patching process... https://www.capturesweden.com/Portals/0/Downloads/Reference%20Manual.pdf#page28 Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
