Headg8 Posted June 6, 2017 Report Posted June 6, 2017 Can anyone suggest how to change the floppy drive so I can input from a USB stick. Is a special config required? Quote
kgallen Posted June 6, 2017 Report Posted June 6, 2017 If you've got a Blue Room login, then swapping the floppy for a paged USB floppy emulator has been covered a number of times. Here is one such link: http://www.blue-room.org.uk/index.php?showtopic=50532&st=60 Look for the postings by user "vinntec" or "PaulDF" who has done this change successfully. With this particular topic you will need to skip a lot of posts talking about the fixture library, so you might have to dig through it a bit. There might be other postings that don't go off topic so much. You can find others with this Google search term: "site:www.blue-room.org.uk frog floppy" https://www.google.co.uk/search?q=site%3Awww.blue-room.org.uk+frog+floppy&oq=site%3Awww.blue-room.org.uk+frog+floppy&aqs=chrome..69i57j69i58.12382j0j8&sourceid=chrome&ie=UTF-8 Kevin Quote
Headg8 Posted June 27, 2017 Author Report Posted June 27, 2017 Thanks Kevin I will try that route. Quote
