kgallen Posted June 2, 2017 Report Share Posted June 2, 2017 Having had to dig around a bit to find the fuse types for the three Alphapack versions, I'm documenting here for other users: All fuses are 6.3A, ceramic HRC fast acting, 5x20mm. Alphapack1: 5x20mm (Note: NOT 32mm as quoted in this datasheet: http://zero88.com/support/index.php?/Knowledgebase/Article/GetAttachment/266/264) Alphapack2: 5x20mm (http://zero88.com/support/index.php?/Knowledgebase/Article/GetAttachment/84/616) Alphapack3: 5x20mm (http://zero88.com/datasheets/Alphapack_3_Datasheet_UK_Rev2_0516.pdf) 5x20mm: RS 563-330 http://uk.rs-online.com/web/p/cartridge-fuses/0563330/ CPC FF02830 (SIBA 70-007-33/6.3A) http://cpc.farnell.com/siba/70-007-33-6-3a/fuse-20x5-ceramic-quick-blow-6/dp/FF02830 Quote Link to comment Share on other sites More sharing options...
iank99 Posted June 5, 2017 Report Share Posted June 5, 2017 Keith will be along in a minute I'm sure but as posted elsewhere - the fuse size is 20mm for all models. The Alphpack Mark 1 didn't have 32mm fuses as the holders wouldn't physically fit the PCB layout. The discrepancy has crept in on the datasheet from when they were re-done when Cooper Industries bought Zero88 and unified/branded all the product spec sheets. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk Link to comment Share on other sites More sharing options...
kgallen Posted June 5, 2017 Author Report Share Posted June 5, 2017 Thanks Ian. I've edited my original post above to try to avoid any future confusion! Quote Link to comment Share on other sites More sharing options...
