SimonH Posted May 21, 2017 Report Share Posted May 21, 2017 When you put selected fixtures in a palette colour it shows that name as the colour which is very helpful as we don't have a copy from function. Only trouble is that it doesn't show the name if a filter is selected. Is there any way this could be made to work? Quote Link to comment Share on other sites More sharing options...
Edward Posted May 23, 2017 Report Share Posted May 23, 2017 Hi Simon, I have had a play and see what you mean. The Palette copy function will be returning soon. When selecting Filters, the filter name will appear in the Command Line of the console, and as you say give RGBW values in the Programmer table. Hope this helps Edward Quote Link to comment Share on other sites More sharing options...
SimonH Posted May 23, 2017 Author Report Share Posted May 23, 2017 Hi Edward, It's not the palette copy that I'm after. What I used to be able to do on an old strand and I think the old Frog would be to copy all attributes from one fixture to another. The copy button on the frog IIRC used to have both channel and playback facility. The Strand desk had a copyfrom button so in syntax would be 58@copyfrom65enter and it would put 65 exactly as 58. Quote Link to comment Share on other sites More sharing options...
Edward Posted May 23, 2017 Report Share Posted May 23, 2017 Hi Simon, Ah I understand what you mean. What console are you using? This is currently available for FROG2 and Orb series consoles, by IIRC using the syntax 58 COLOUR COPY 65 will copy 58's colour to 65. Hope this helps Edward Quote Link to comment Share on other sites More sharing options...
SimonH Posted May 23, 2017 Author Report Share Posted May 23, 2017 Hi, I'm using an FLX if that makes a difference. Cheers, Simon Quote Link to comment Share on other sites More sharing options...
Edward Posted May 23, 2017 Report Share Posted May 23, 2017 Hi Simon, I believe this is not available on FLX at the moment, however is something I'm pretty sure is in the pipeline to be included. Edward Quote Link to comment Share on other sites More sharing options...
