SimonH Posted April 3, 2017 Report Share Posted April 3, 2017 copy the attributes on one fixture to another? (like the @copyfrom on the old strand desks) REMDIM? Thanks Quote Link to comment Share on other sites More sharing options...
Edward Posted April 4, 2017 Report Share Posted April 4, 2017 Hello, I don't believe there is currently a way of doing this on FLX, however I may be wrong. I know you can with FROG2 which is running the same software so the function must be in there. To get the REMDIM function you can setup a UDK you're not using for REMDIM. To do this choose an empty UDK and hold SETUP + press it. You can then set it to have a function and shifted function, so you can choose REM DIM from the drop down list. Hope this helps Edward Quote Link to comment Share on other sites More sharing options...
SimonH Posted April 5, 2017 Author Report Share Posted April 5, 2017 great thanks. Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted April 6, 2017 Report Share Posted April 6, 2017 Ed's correct, this is available on ORB Series and FROG2, but not currently FLX. One way you can get around it is to record palettes of the fixture you want to copy, and then apply that palette to the new fixture - but this is a little bit long winded. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
SimonH Posted April 6, 2017 Author Report Share Posted April 6, 2017 How do I use the REMDIM via the remote software as I mainly use it whilst focussing? Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted April 6, 2017 Report Share Posted April 6, 2017 How do I use the REMDIM via the remote software as I mainly use it whilst focussing? Currently there's no way to do that via the Apps. I've added an request (reference ZOS-7667) for this to be added to the App screens. It's also a feature we're implementing on the Watch App. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
SimonH Posted September 12, 2017 Author Report Share Posted September 12, 2017 Is the copy from function going to be added to the FLX given the software can achieve it? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted September 12, 2017 Report Share Posted September 12, 2017 Hi Simon, This will be implemented once the other Copy features are implemented on FLX. Kind regards Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
